HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Wavelet Algorithms for Complex Models
François Cuny 1 Christophe Winkler Laurent Alonso Jean-Claude Paul
1 ISA - Models, algorithms and geometry for computer graphics and vision
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : We present the result of experimentations and tests with Wavelet Radiosity. We have developed a powerful wavelet radiosity implementation where we can independantly modify every geometrical component of the scene (description of the input data, representation of spectral distribution, etc.) and every component of the global illumination algorithm (visibility algorithm, wavelet basis, etc.). This implementation has been tested on real world applications: an archaeological site reconstruction with daylight illumination, an opera house front with artificial illumination and the Soda Hall building inside illumination. In this paper, wepresent the results of our experiments, which are mostly about the interdependencies of the different parts of the general algorithm and the influence of each one on the final result. We also introduce several improvements to the wavelet radiosity algorithm that allow for higher rendering speed and lower memory use, thereby allowing rendering of architectural models of high complexity.
Document type :
Reports
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00098732
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:21:36 AM
Last modification on : Friday, February 4, 2022 - 3:30:15 AM
Long-term archiving on: : Friday, November 25, 2016 - 11:44:37 AM
Identifiers
  • HAL Id : inria-00098732, version 1
Collections
Citation
François Cuny, Christophe Winkler, Laurent Alonso, Jean-Claude Paul. Wavelet Algorithms for Complex Models. [Intern report] 98-R-207 || cuny98a, 1998, 13 p. ⟨inria-00098732⟩
Share
Metrics
Record views
138
Files downloads
22
