A bridge between two paradigms for parallelism : Neural Networks and general purpose MIMD computers. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Yann Boniface
  • Fonction : Auteur
  • PersonId : 835315
Frédéric Alexandre
Stéphane Vialle
Recent hardware developments have led to use shared memory as an efficient parallel programming way. The main goals of the work reported here are to speed up executions and to decrease development time of parallel neural networks implementations. To allow for such implementations, a library has been defined, as a bridge between neural networks and general purpose MIMD computer parallelisms.
Autre [cs.OH]
99-R-155.pdf (186.47 Ko) Télécharger le fichier
inria-00098761 , version 1 (26-09-2006)
  • HAL Id : inria-00098761 , version 1
Yann Boniface, Frédéric Alexandre, Stéphane Vialle. A bridge between two paradigms for parallelism : Neural Networks and general purpose MIMD computers.. International Joint Conference on Neural Networtks - IJCNN'99, 1999, Washington, DC, 6 p. ⟨inria-00098761⟩
55 Consultations
184 Téléchargements
