Time distribution and synchronization
The time synchronisation is needed for different functions in a distributed system. For instance, CMM functions must notice the dates of some operations as the updating of a parameter, the modification of a configuration ; in an other hand these functions may require a time reference for the management of time constraints at the run time step of a real time application.
