Structural Sharing and Efficient Proof-Search in Propositional Intuitionistic Logic - Archive ouverte HAL Access content directly
Conference Papers Year : 1999
In this paper, we present a new system for proof-search in propositional intuitionistic logic from which an efficient implementation based on structural sharing is naturally derived. The way to solve the problem of formula duplication is not based on logical solutions but on an appropriate representation of sequents with a direct impact on sharing and therefore on the implementation. Then, the proof-search is based on a finer control of the resources and has a ${\cal O}(n\log n)$-space complexity. The system has the subformula property and leads to an algorithm that, for a given sequent, constructs a proof or generates a counter-model.
Not file
Dates and versions
inria-00098992 , version 1 (26-09-2006)
Identifiers
  • HAL Id : inria-00098992 , version 1
Cite
Didier Galmiche, Dominique Larchey-Wendling. Structural Sharing and Efficient Proof-Search in Propositional Intuitionistic Logic. Asian Computing Science Conference - ASIAN'99, 1999, Phuket, Thailand, pp.101-112. ⟨inria-00098992⟩
48 View
0 Download
Share
