Abstract : In this paper, a method for analytic handwritten word recognition based on causal Markov random fields is described. The words models are hmms where each state corresponds to a letter; each letter is modelled by a nshp-hmm (Markov field). Global models are build dynamically, and used for recognition and learning with the baum-welch algorithm. Learning of letter and word models is made using the parameters reestimated on the generated global models. No segmentation is necessary: the system determines itself the best limits between the letters during learning. First experiments on a real base of french check amount words give encouraging results of 83.4% for recognition.
https://hal.inria.fr/inria-00099041
Contributor : Publications Loria <>
Submitted on : Tuesday, September 26, 2006 - 8:47:39 AM Last modification on : Friday, February 26, 2021 - 3:28:07 PM Long-term archiving on: : Wednesday, March 29, 2017 - 12:36:17 PM
Christophe Choisy, Abdel Belaïd. Analytic word recognition without segmentation based on Markov random fields. 7th International Workshop on Frontiers in Handwriting Recognition - IWFHR'2000, 2000, Amsterdam, Hollande. ⟨inria-00099041⟩
