The simply typed rewriting calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
The rewriting calculus is a rule construction and application framework. As such it embeds in a uniform way term rewriting and lambda-calculus. Since rule application is an explicit object of the calculus, it allows us also to handle the set of results explicitly. We present a simply typed version of the rewriting calculus. With a good choice of the type system, we show that the calculus is type preserving and terminating, i.e. verifies the subject reduction and strong normalization properties.
A00-R-237.pdf (267 Ko) Télécharger le fichier
inria-00099052 , version 1 (26-09-2006)
  • HAL Id : inria-00099052 , version 1
Horatiu Cirstea, Claude Kirchner. The simply typed rewriting calculus. 3rd International Workshop on Rewriting Logic & its Applications - WRLA2000, Sep 2000, none, 19 p. ⟨inria-00099052⟩
76 Consultations
87 Téléchargements
