Objects, rules and strategies in ELAN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper gives an introduction to the ELAN rule-based programming language and presents a general approach for prototyping a new language by transformations defined in ELAN. The approach is used to design an extension of ELAN with objects, leading to an expressive programming framework that combines the concepts of objects, rules and strategies.
A00-R-246.pdf (337.88 Ko) Télécharger le fichier
inria-00099054 , version 1 (26-09-2006)
  • HAL Id : inria-00099054 , version 1
Hubert Dubois, Hélène Kirchner. Objects, rules and strategies in ELAN. 2nd AMAST Workshop on Algebraic Methods in Language Processing - AMILP'2000, 2000, Iowa City, Iowa, USA, 19 p. ⟨inria-00099054⟩
47 Consultations
70 Téléchargements
