Parallel Molecular Dynamics Using OpenMP on a Shared Memory Machine
Raphael Couturier 1 Christophe Chipot
1 MODEL - MODEL (Méthodes formelles et applications)
LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The parallelization of a sequentiel molecular dynamics (MD) program using OpenMP directives for a Fortran compiler is described. The strength of this approach lies in the possibility to proceed incrementally, with no to only few alterations of the original, scalar code. If do-loop splitting with OpenMP is certainly less effecient than domain decomposition (DD) approaches, its fast implementation, requiring little knowledge of the source code, also involves significantly less programming effort. Efficiency of the parallel executable is probed on a distributed-shared memory Silicon Graphics Origin 2000 for MD applications of various complexities. Linear wallclock speed-up ratios using four processors, and ranging between 6.0 and 7.0 with eight, undeline the cost-effectiveness of OpenMP directives for fine-grained MD simulations on limited computational resources.
Type de document :
Article dans une revue
Computer Physics Communications, Elsevier, 2000, 124 (1), pp.49-59
Liste complète des métadonnées
https://hal.inria.fr/inria-00099083
Contributeur : Publications Loria <>
Soumis le : mardi 26 septembre 2006 - 08:50:49
Dernière modification le : jeudi 11 janvier 2018 - 06:21:04
  • HAL Id : inria-00099083, version 1
Collections
Citation
Raphael Couturier, Christophe Chipot. Parallel Molecular Dynamics Using OpenMP on a Shared Memory Machine. Computer Physics Communications, Elsevier, 2000, 124 (1), pp.49-59. 〈inria-00099083〉
Métriques
Consultations de la notice
140
