Case-Based Reasoning for Breast Cancer Treatment Decision Helping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper presents two applications for the breast cancer treatment decision helping. The first one is called Casimir/RBR and can be likened to a rule-based reasoning system. It is now fully implemented. In some situations, the application of the rules of this system does not provide a satisfying treatment. Then, the application Casimir/CBR --which is not fully implemented-- can be used. Casimir/CBR uses principles of case-based reasoning in order to suggest solutions by adapting the rules of Casimir/RBR. In this framework, the rules are considered as cases: they are adapted rather than used literally.
Fichier non déposé
inria-00099202 , version 1 (26-09-2006)
  • HAL Id : inria-00099202 , version 1
Jean Lieber, Benoît Bresson. Case-Based Reasoning for Breast Cancer Treatment Decision Helping. fifth European Workshop on Case-Based Reasoning - EWCBR'2000, 2000, Trento, Italie, pp.173--185. ⟨inria-00099202⟩
113 Consultations
0 Téléchargements
