New interface
Conference papers
Subtractive Reductions and Complete Problems for Counting Complexity Classes
Abstract : We introduce and investigate a new type of reductions between counting problems, which we call subtractive reductions. We show that the main counting complexity classes #P, #NP, as well as all higher counting complexity classes #.Pi_k P, k > 2, are closed under subtractive reductions. We then pursue problems that are complete for these classes via subtractive reductions. We focus on the class #NP (which is the same as the class #.coNP) and show that it contains natural complete problems via subtractive reductions, such as the problem of counting the minimal models of a Boolean formula in conjunctive normal form and the problem of counting the cardinality of the set of minimal solutions of a homogeneous system of linear Diophantine inequalities.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00099381
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:53:27 AM
Last modification on : Friday, February 4, 2022 - 3:29:46 AM
Identifiers
  • HAL Id : inria-00099381, version 1
Collections
Citation
Arnaud Durand, Miki Hermann, Phokion G. Kolaitis. Subtractive Reductions and Complete Problems for Counting Complexity Classes. 25th International Symposium on Mathematical Foundations of Computer Science - MFCS'2000, 2000, Bratislava, Slovaquie, pp.323-332. ⟨inria-00099381⟩
Share
Metrics
Record views
99
