Detection of the Discrete Convexity of Polyominoes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 2003
The convexity of a discrete region is a property used in numerous domains of computational imagery. We study its detection in the particular case of polyominoes. We present a first method, directly relying on its definition. A second method, which is based on techniques for segmentation of curves in discrete lines, leads to a very simple, linear algorithm, whose correction is proven. Correlatively, we obtain a characterisation of lower and upper frontiers of the convex hull of a discrete line segment. Finally, we evoke some applications of these results to the problem of discrete tomography.
Fichier non déposé
inria-00099507 , version 1 (26-09-2006)
  • HAL Id : inria-00099507 , version 1
Isabelle Debled-Rennesson, Jean-Luc Rémy, Jocelyne Rouyer-Degli. Detection of the Discrete Convexity of Polyominoes. Discrete Applied Mathematics, 2003, 125 (1), pp.115-133. ⟨inria-00099507⟩
58 Consultations
0 Téléchargements
