Outermost ground termination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Notes in Theoretical Computer Science Année : 2003
We propose a semi-automatic inductive process to prove termination of outermost rewriting on ground term algebras. The method is based on an abstraction mechanism, schematizing normalisation of subterms, and on narrowing, schematizing reductions on ground terms. The induction ordering is not needed a priori, but is a solution of constraints set along the proof. Our method applies in particular to systems that are non-terminating for the standard strategy nor even for the lazy strategy.
Fichier non déposé
inria-00099654 , version 1 (26-09-2006)
  • HAL Id : inria-00099654 , version 1
Olivier Fissore, Isabelle Gnaedig, Hélène Kirchner. Outermost ground termination. Electronic Notes in Theoretical Computer Science, 2003, 71, 20 p. ⟨inria-00099654⟩
65 Consultations
0 Téléchargements
