HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Unions of Non-Disjoint Theories and Combinations of Satisfiability Procedures
Cesare Tinelli Christophe Ringeissen 1
1 PROTHEO - Constraints, automatic deduction and software properties proofs
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In this paper we outline a theoretical framework for the combination of decision procedures for constraint satisfiability. We describe a general combination method which, given a procedure that decides constraint satisfiability with respect to a constraint theory T1 and one that decides constraint satisfiability with respect to a constraint theory T2, produces a procedure that (semi-)decides constraint satisfiability with respect to the union of T1 and T2. We provide a number of model-theoretic conditions on the constraint language and the component constraint theories for the method to be sound and complete, with special emphasis on the case in which the signatures of the component theories are non-disjoint. We also describe some general classes of theories to which our combination results apply, and relate our approach to some of the existing combination methods in the field.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00099668
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 9:39:57 AM
Last modification on : Friday, February 4, 2022 - 3:22:17 AM
Identifiers
  • HAL Id : inria-00099668, version 1
Collections
Citation
Cesare Tinelli, Christophe Ringeissen. Unions of Non-Disjoint Theories and Combinations of Satisfiability Procedures. Theoretical Computer Science, Elsevier, 2003, 290 (1), pp.291-353. ⟨inria-00099668⟩
Share
Metrics
Record views
48
