Frequency and Wavelet Filtering for Robust Speech Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Mel-frequency cepstral coefficients (MFCC) are the most widely used features in current speech recognition systems. However, they have a poor physical interpretation and they do not lie in the frequency domain. Frequency filtering (FF) is a technique that has been recently developed to design frequency-localized speech features that perform similar to MFCC in terms of recognition performances. Motivated by our desire to build time-frequency speech models, we wanted to use the FF technique as front-end. However, when evaluating FF on the Aurora-3 database we found some discrepancies in the highly mismatch case. This led us to put FF in another perspective: the wavelet transform. By doing so, we were able to explain the discrepancies and to achieve significant improvements in recognition in the highly mismatch case.
Fichier non déposé
inria-00099753 , version 1 (26-09-2006)
  • HAL Id : inria-00099753 , version 1
Murat Deviren, Khalid Daoudi. Frequency and Wavelet Filtering for Robust Speech Recognition. Artificial Neural Networks and Neural Information Processing - Joint International Conference ICANN/ICONIP2003, 2003, Istanbul, Turquie, pp.452-462. ⟨inria-00099753⟩
56 Consultations
0 Téléchargements
