Abstract : In this paper, we have extended the approach defined in "Debled-Rennesson et al, Segmentation of discrete curves into fuzzy segments,IWCIA'03" to a multiorder analysis. The approach is based on the arithmetical definition of discrete lines with variable thickness. We provide a framework to analyse a digital curve at different levels of thickness. The extremities points of a segment provided at a high resolution are tracked at lower resolution in order to refine their location. The high resolution level is automatically defined from the stability of the number of segments between two consecutive levels. The method is threshold-free and automatically provides a partitioning of a digital curve into its meaningful parts.
Isabelle Debled-Rennesson, Salvatore Tabbone, Laurent Wendling. Fast polygonal approximation of digital curves. 17th International Conference on Pattern Recognition - ICPR'04, Aug 2004, Cambridge, United Kingdom, pp.465-468. ⟨inria-00100038⟩
