HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Predicting and Controlling Resource Usage in a Heterogeneous Active Network
Virginie Galtier 1 Kevin Mills 2 Yannick Carlinet 2 Stephen Bush Amit Kulkarni
1 RESEDAS - Software Tools for Telecommunications and Distributed Systems
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Active network technology envisions deployment of virtual execution environments within network elements, such as switches and routers. As a result, inhomogeneous processing can be applied to network traffic. To use such technology safely and efficiently, individual nodes must provide mechanisms to enforce resource limits. This implies that each node must understand the varying resource requirements for specific network traffic. This paper presents an approach to model the CPU time requirements of active applications in a form that can be interpreted among heterogeneous nodes. Further, the paper demonstrates how this approach can be used successfully to control resources consumed at an active-network node and to predict load among nodes in an active network, when integrated within the Active Virtual Network Management Prediction system.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00100439
Contributor : Véronique Prêtre Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:45:25 PM
Last modification on : Friday, February 4, 2022 - 3:25:20 AM
Identifiers
  • HAL Id : inria-00100439, version 1
Collections
Citation
Virginie Galtier, Kevin Mills, Yannick Carlinet, Stephen Bush, Amit Kulkarni. Predicting and Controlling Resource Usage in a Heterogeneous Active Network. Third Annual International Workshop on Active Middleware Services, 2001, San Francisco, USA, 10 p. ⟨inria-00100439⟩
Share
Metrics
Record views
71
