Population improvement with data oriented genetic operators
Marie-Claude Portmann 1 Mohamed Ali Aloulou 1
1 MACSI - Industrial system modeling, analysis and operation
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In this paper, we consider various particular cases of the one-machine scheduling problem. The general problem considered is denoted by 1/r_i,S_{sd}/sum_{w_iT_i} in the Graham's notation, i.e. the one-machine problem with non identical release dates, sequence dependent set-up times and the weighted sum of tardiness as measure of performance. We will also consider the makespan criterion. We propose new genetic operators called "data oriented" because they use not only the permutation (order of the operations) contained in the chromosome but also an analysis of the corresponding solution. One family of data oriented operators focuses on the set-up times minimization and thus indirectly on the tardiness costs, the other one focuses directly on the tardiness cost. When the release dates are identical, each chromosome is the direct representation of the solution (direct encoding). When the release dates are not identical, the only way to remain efficient is to use active generators such as Baker's or Carlier's generators to convert the permutation contained in the chromosome (considered now as priority order of the operations) into an active schedule (indirect encoding). Only the tardiness oriented operators may be used in the latter case. Experimental results show the efficiency of the new proposed operators.
Type de document :
Communication dans un congrès
Lee Spector. Proceedings of the Genetic and Evolutionary Computation Conference - GECCO'2001, 2001, San Francisco, USA, pp.339-346, 2001
Liste complète des métadonnées
https://hal.inria.fr/inria-00100512
Contributeur : Publications Loria <>
Soumis le : mardi 26 septembre 2006 - 14:46:23
Dernière modification le : jeudi 11 janvier 2018 - 06:19:48
  • HAL Id : inria-00100512, version 1
Collections
Citation
Marie-Claude Portmann, Mohamed Ali Aloulou. Population improvement with data oriented genetic operators. Lee Spector. Proceedings of the Genetic and Evolutionary Computation Conference - GECCO'2001, 2001, San Francisco, USA, pp.339-346, 2001. 〈inria-00100512〉
Métriques
Consultations de la notice
81
