Abstract : The rho-calculus integrates in a uniform and simple setting first-order rewriting, lambda-calculus and non-deterministic computations. Its abstraction mechanism is based on the rewrite rule formation and its main evaluation rule is based on matching modulo a theory T. We have seen in the first part of this work the motivations, definitions and basic properties of the rho-calculus. This second part is first devoted to the use of an extension of the rho-calculus for encoding a (conditional) rewrite relation. This extension is based on the ``first'' operator whose purpose is to detect rule application failure. It allows us to express recursively rule application and therefore to encode strategy based rewriting processes. We then use this extended calculus to give an operational semantics to ELAN programs. We conclude with an overview of ongoing and future works on rho-calculus.
Horatiu Cirstea, Claude Kirchner. The Rewriting Calculus - Part II. Logic Journal of the IGPL, Oxford University Press (OUP), 2001, 9 (3), pp.465-498. ⟨10.1093/jigpal/9.3.377⟩. ⟨inria-00100532⟩
