Abstract : PURPOSE: To evaluate three-dimensional (3D) digital subtraction angiography (DSA) as a supplement to two-dimensional (2D) DSA in the endovascular treatment (EVT) of intracranial aneurysms. MATERIALS AND METHODS: In 22 ruptured aneurysms, neck visualization, aneurysm shape, and EVT feasibility were analyzed at 2D DSA (anteroposterior, lateral, rotational views) and at maximum intensity projection (MIP) and surface shaded display (SSD) 3D DSA. The possibility of obtaining a working view for EVT at 3D DSA and the relevance of measurements in choosing the first coil also were assessed. RESULTS: Two-dimensional DSA images clearly depicted the aneurysm neck in four of 22 aneurysms; MIP images, in 10; and SSD images, in 21, but SSD led to overestimation of the neck size in one aneurysm. Aneurysm shape was precisely demonstrated in five of 22 aneurysms, EVT seemed to be nonfeasible at 2D DSA; however, SSD demonstrated feasibility and EVT was successfully performed. In one aneurysm, only SSD demonstrated the extension of the neck to a parent vessel, which was proved at surgery. Working views for EVT were deduced from 3D DSA findings in 20 of 21 aneurysms. The choice of the first coil was correct in 19 of 21 aneurysms. CONCLUSION: Three-dimensional DSA is valuable for evaluating the potential for EVT, finding a working view, and performing accurate measurements.
