Tree-Structured Maximum a Posteriori Adaptation for a Segment-Based Speech Recognition System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Irina Illina
In this paper, the problem of the adaptation of a speech recognition system to a new environment is addressed. Recently, a Structural Maximum a Posteriori adaptation (SMAP) for a frame-based HMM model adaptation has been developed. In this method, acoustic model pdfs are organised in a tree and the means and variances of the pdfs are adapted using the linear transformations estimated under MAP criteria. In this paper, we extend the SMAP adaptation to a segment-based model: the Mixture Stochastic Trajectory Model (MSTM). SMAP approach is completed by the tree construction driven by adaptation data, a Minimum Description Length (MDL) structure definition of this tree and trajectory and state adaptations. On the Resource Management task, the speaker adaptation and noise adaptation experiments show that the proposed SMAP approach gives a significant improvement compared to unadapted system.
Fichier non déposé
inria-00100756 , version 1 (26-09-2006)
  • HAL Id : inria-00100756 , version 1
Irina Illina. Tree-Structured Maximum a Posteriori Adaptation for a Segment-Based Speech Recognition System. 7th International Conference on Spoken Language Processing - ICSLP'02, 2002, Denver, Colorado, USA, 4 p. ⟨inria-00100756⟩
83 Consultations
0 Téléchargements
