Standards for Language Resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
This paper presents an abstract data model for linguistic annotations and its implementation using XML, RDF and related standards; and to outline the work of a newly formed committee of the International Standards Organization (ISO), ISO/TC 37/SC 4 Language Resource Management, which will use this work as its starting point. The primary motive for presenting the latter is to solicit the participation of members of the research community to contribute to the work of the committee.
ide-romary-LREC02.pdf (258.82 Ko) Télécharger le fichier
inria-00100771 , version 1 (14-09-2009)
  • HAL Id : inria-00100771 , version 1
  • ARXIV : 0909.2719
Nancy Ide, Laurent Romary. Standards for Language Resources. LREC 2002 - Third International Conference on Language Resources and Evaluation, May 2002, Las Palmas, Spain. pp.9. ⟨inria-00100771⟩
160 Consultations
87 Téléchargements
