Scan-to-XML : Automatic Generation of Browsable Technical Documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Ernest Valveny
  • Fonction : Auteur
In this paper we experiment and validate an approach for the automatic generation of browsable technical documents. The application demonstrated in this work is restricted to cutaway diagrams with a particular visual representation. The global approach in which it is integrated is of a far more general interest, however. Our principal aim is to automatically generate an XML description of a graphical document that will allow for further use of its content by establishing links within the document or with other documents, thus constructing a corpus of interconnected documents sharing zones of similar content or semantics.
Fichier non déposé
inria-00100890 , version 1 (26-09-2006)
  • HAL Id : inria-00100890 , version 1
Ernest Valveny, Bart Lamiroy. Scan-to-XML : Automatic Generation of Browsable Technical Documents. Sixteenth International Conference on Pattern Recognition - ICPR 2002, IAPR, 2002, Québec city, QC, Canada, pp.188-192. ⟨inria-00100890⟩
54 Consultations
0 Téléchargements
