HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Synthesis of a closed-loop combined plant and controller model
Gülgün Alpan 1 Mohsen A. Jafari
1 TRIO - Real time and interoperability
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In practice, a controlled system consists of two distinct entities: the plant and the controller. These two entities are coupled by a feedback mechanism to give the closed-loop behavior of the controlled system. Under this structure, the controlled behavior of the system can be analyzed by simulation which is costly and time consuming. In this study, we synthesize a combined plant and controller model. We consider the practical issues and propose a method which combines the advantages of Petri nets (PN) and the supervisory controller design based on Formal Language Theory. The resultant combined model is a PN and represents the controlled closed-loop behavior of the system. This model can be used for the functional and the performance analysis of the system, verification of the controller and the control code generation.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00100901
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:52:46 PM
Last modification on : Friday, February 4, 2022 - 3:11:11 AM
Identifiers
Collections
Citation
Gülgün Alpan, Mohsen A. Jafari. Synthesis of a closed-loop combined plant and controller model. IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics, Institute of Electrical and Electronics Engineers, 2002, 32 (2), pp.163-175. ⟨10.1109/3477.990873⟩. ⟨inria-00100901⟩
Share
Metrics
Record views
53
