On the Cohen-Olivier algorithm for computing zeta(s): error analysis in the real case for an arbitrary precision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
We provide a complete error analysis of the Cohen-Olivier algorithm, for computing the zeta function, when the argument is real.
Fichier non déposé
inria-00101071 , version 1 (26-09-2006)
  • HAL Id : inria-00101071 , version 1
Yves Pétermann, Jean-Luc Rémy. On the Cohen-Olivier algorithm for computing zeta(s): error analysis in the real case for an arbitrary precision. [Intern report] A02-R-387 || petermann02b, 2002. ⟨inria-00101071⟩
29 Consultations
0 Téléchargements
