Probabilistic Polynomial-time Semantics for a Protocol Security Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We describe a cryptographically sound formal logic for proving protocol security properties without explicitly reasoning about probability, asymptotic complexity, or the actions of a malicious attacker. The approach rests on a new probabilistic, polynomial-time semantics for an existing protocol security logic, replacing an earlier semantics that uses nondeterministic symbolic evaluation. While the basic form of the protocol logic remains unchanged from previous work, there are some interesting technical problems involving the difference between efficiently recognizing and efficiently producing a value, and involving a reinterpretation of standard logical connectives that seems necessary to support certain forms of reasoning.
Fichier non déposé
inria-00103654 , version 1 (04-10-2006)
  • HAL Id : inria-00103654 , version 1
Anupam Datta, Ante Derek, John C. Mitchell, Vitaly Shmatikov, Mathieu Turuani. Probabilistic Polynomial-time Semantics for a Protocol Security Logic. 32nd International Colloquium on Automata, Languages and Programming - ICALP 2005, Jul 2005, Lisbon/Portugal, pp.16--29. ⟨inria-00103654⟩
90 Consultations
0 Téléchargements
