Advanced visualization for various unstructured grids using ah hoc topological structures
Abstract : Flexible grids are used in many Geoscience applications because they can accurately adapt to the great diversity of shapes encountered in nature. These grids raise a number di cult challenges, in particular for fast volume visualization. We propose a generic incremental slicing algorithm for versatile visualization of unstructured grids, these being constituted of arbitary convex cells. The tradeo between the complexity of the grid and the e ciency of the method is addressed by special-purpose data structures and customizations. A general structure based on oriented edges is defined to address the general case. When only a limited number of polyhedron types are present in the grid (zoo grids), memory usage and rendering time are reduced by using a catalog of cell types generated automatically. This data structure is further optimized to deal with stratigraphic grids made of hexahedral cells. The visualization method is applied to several gridded subsurface models conforming to geological structures.
Type de document :
Article dans une revue
Computers and Geosciences, Elsevier, 2004, 32 p
Liste complète des métadonnées
https://hal.inria.fr/inria-00105629
Contributeur : Nicolas Ray <>
Soumis le : mercredi 11 octobre 2006 - 16:38:13
Dernière modification le : mercredi 25 juillet 2018 - 09:59:57
  • HAL Id : inria-00105629, version 1
Collections
Citation
Guillaume Caumon, Bruno Lévy, Laurent Castanie, Jean-Claude Paul. Advanced visualization for various unstructured grids using ah hoc topological structures. Computers and Geosciences, Elsevier, 2004, 32 p. 〈inria-00105629〉
Métriques
Consultations de la notice
390
