Computation of Discrete Logarithms in GF(2^607) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
We describe in this article how we have been able to extend the record for computations of discrete logarithms in characteristic 2 from the previous record over GF(2^503) to a newer mark of GF(2^607), using Coppersmith's algorithm. This has been made possible by several practical improvements to the algorithm. Although the computations have been carried out on fairly standard hardware, our opinion is that we are nearing the current limits of the manageable sizes for this algorithm, and that going substantially further will require deeper improvements to the method.
dlrecord.pdf (196.41 Ko) Télécharger le fichier
inria-00107488 , version 1 (18-10-2006)
Emmanuel Thomé. Computation of Discrete Logarithms in GF(2^607). Advances in Cryptology -- ASIACRYPT 2001, International Association for Cryptologic Research, Dec 2001, Gold Coast, Queensland, Australia. pp.107-124, ⟨10.1007/3-540-45682-1_7⟩. ⟨inria-00107488⟩
301 Consultations
342 Téléchargements
