An Architecture Description Language For In-Vehicle Embedded System Development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
This papers presents the AEE project , a french cooperative research and development program whose purpose is to specify new solutions for in-vehicle embedded system development. The architecture Implementation Language (AIL) has been defined to specify and to describ precisely any vehicle electronic architecture. AIL supports the AEE design process, and is used by all designers as the backbone of the architecture development. Finally AIL is used to define reusble architecture objects.
A01-R-282.pdf (129.34 Ko) Télécharger le fichier
inria-00107546 , version 1 (19-10-2006)
  • HAL Id : inria-00107546 , version 1
Jean-Pierre Elloy, Françoise Simonot-Lion. An Architecture Description Language For In-Vehicle Embedded System Development. [Intern report] A01-R-282 || elloy01a, 2001, 6 p. ⟨inria-00107546⟩
97 Consultations
178 Téléchargements
