Contribution to the understanding of explanatory factors for the decision-maker problem within the framework of economic intelligence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Najoua Bouaka
  • Fonction : Auteur
  • PersonId : 830524
Amos David
Odile Thiery
  • Fonction : Auteur
In an economic intelligence context, the decision-maker is more and more intersted in changes of him complex environment.To help him face these situations, we propose a decision-maker model based on a set of parameters that describe the decision-maker?s behavior as regards a problem. These parameters are related to the decision-maker as an individual, to the organization and the environment to which it belongs. The model of the decision-maker presented in this paper, thanks to its support for the decision-maker, allows the watcher to better understand a concrete problem posed by a given decision-maker and thus allows the watcher to seek for and to produce analyses of the most relevant information.
A02-R-116.pdf (103.03 Ko) Télécharger le fichier
inria-00107559 , version 1 (19-10-2006)
  • HAL Id : inria-00107559 , version 1
Najoua Bouaka, Amos David, Odile Thiery. Contribution to the understanding of explanatory factors for the decision-maker problem within the framework of economic intelligence. 6th World Multiconference on Systimics, Cybernetics and Informatics - SCI' 2002, 2002, Orlando, Florida, USA, 5 p. ⟨inria-00107559⟩
181 Consultations
128 Téléchargements
