Real-time communications in distributed control systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Ye-Qiong Song
This presentation outlines the results of the two PRA projects : the completed PRA SI99-04 and the on going PRA SI01-04. Both of the two research projects belong to real-time communication area. PRA SI99-04 is dedicated to in-vehicle embedded systems using CAN network while PRA SI01-04 deals with the factory automation using both traditional fieldbus and newly adopted switched Industrial Ethernet. Some comments and suggestions on the possible future Franco-Chinese collaboration research are given.
A02-R-318.pdf (254.47 Ko) Télécharger le fichier
inria-00107606 , version 1 (19-10-2006)
  • HAL Id : inria-00107606 , version 1
Ye-Qiong Song. Real-time communications in distributed control systems. Sino-French PRA (Programme de Recherches Avancées) workshop on Information Science and Technology, Nov 2002, Beijing/China, 15 p. ⟨inria-00107606⟩
149 Consultations
86 Téléchargements
