HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Robust speech recognition to non-stationary and unpredictable noise based on model-driven approaches
Christophe Cerisara 1 Irina Illina 1
1 PAROLE - Analysis, perception and recognition of speech
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Automatic speech recognition works quite well in clean conditions, and several algorithms have already been proposed to deal with stationary noise. The next challenge probably consists to compensate for non-stationary noise as well. This work studies this problem by proposing and comparing two adaptations of the Parallel Model Combination (PMC) algorithm for non-stationary noise. A third method, derived from the missing data framework, is further proposed and compared to the two previous ones. In musical noise, experimental results show an important improvement of the recognition accuracy for one PMC-derived algorithm, compared to the non adapted system. The missing-data algorithm also performs quite well, despite its simplicity and the strong assumptions he is using.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00107647
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Thursday, October 19, 2006 - 9:03:58 AM
Last modification on : Friday, February 26, 2021 - 3:28:05 PM
Long-term archiving on: : Wednesday, March 29, 2017 - 1:21:25 PM
Identifiers
  • HAL Id : inria-00107647, version 1
Collections
Citation
Christophe Cerisara, Irina Illina. Robust speech recognition to non-stationary and unpredictable noise based on model-driven approaches. 8th European Conference on Speech Communication and Technology - EUROSPEECH'03, Sep 2003, Geneva, Switzerland, 4 p. ⟨inria-00107647⟩
Share
Metrics
Record views
62
Files downloads
44
