Solving Layout Problems Concurrently With TeX and Java - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Tugboat Année : 2003
This paper describes a cooperation between Java and TeX in order to lay out texts in a logical way. An optimal solution is found through a binary search applied to TeX runs. Concurrency is used both within Java, with a tree of Java threads corresponding to the structure of the page, and outside Java because external formatting processes are forked. This represents a first step towards the use of concurrency by a domain that has hitherto ignored it.
Autre [cs.OH]
Fichier sous embargo
Date de visibilité indéterminée
inria-00107696 , version 1 (19-10-2006)
  • HAL Id : inria-00107696 , version 1
Denis Roegel. Solving Layout Problems Concurrently With TeX and Java. Tugboat, 2003, 8 p. ⟨inria-00107696⟩
118 Consultations
5 Téléchargements
