The Use of 3D Xray angiographic Images for Volume Determination of Cerebral Arteriovenous Malformations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The radiotherapic treatment of cerebral arterious malformations (AVM) requires an accurate estimation of the AVM shape. This estimation is classically obtained from the delineation of the AVM in several 2D angiographic views. In this paper, a clinical study of the inter-observer variability in the AVM detection is first performed. It proves that the estimated volume varies a lot between observers. For these reasons, we propose a framework for AVM delineation which makes use of 2D and 3D angiographic images: the initial estimate obtained with 2D angiographic images is then refined within the 3D volume using deformable models. Results are presented demonstrating shape delineation on various AVMs.
Autre [cs.OH]
A04-R-089.pdf (868.81 Ko) Télécharger le fichier
inria-00107783 , version 1 (19-10-2006)
  • HAL Id : inria-00107783 , version 1
Marie-Odile Berger, René Anxionnat, Erwan Kerrien. The Use of 3D Xray angiographic Images for Volume Determination of Cerebral Arteriovenous Malformations. SPIE Medical Imaging 2004, 2004, San Diego, pp.634-643. ⟨inria-00107783⟩
120 Consultations
96 Téléchargements
