Secure XML-based Network Management in a Multi-source Context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
This paper presents a secure architecture for network management in an XML environment. It introduces a distributed access control mechanism based on RBAC directly integrated into XML network configuration documents. It also provides confidentiality and authentication to the protocol both being deeply bound to the role concept of the RBAC model. It also uses an efficient key distribution mechanism based on multicast key management. A prototype implementing this security architecture is under development.
Autre [cs.OH]
A04-R-080.pdf (326.75 Ko) Télécharger le fichier
inria-00107808 , version 1 (19-10-2006)
  • HAL Id : inria-00107808 , version 1
Vincent Cridlig, Radu State, Olivier Festor. Secure XML-based Network Management in a Multi-source Context. [Intern report] A04-R-080 || cridlig04a, 2004, 12 p. ⟨inria-00107808⟩
106 Consultations
43 Téléchargements
