Support Vector Committee machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Dominique Martinez
This paper proposes a mathematical programming framework for combining SVMs with possibly different kernels. Compared to single SVMs, the advantage of this approach is twofold: it creates SVMs with local domains of expertise leading to local enlargements of the margin, and it allows the use of simple linear kernels combined with a fixed boolean operation that is particularly well suited for building dedicated hardware.
Autre [cs.OH]
A00-R-033.pdf (508.22 Ko) Télécharger le fichier
inria-00107847 , version 1 (19-10-2006)
Paternité
  • HAL Id : inria-00107847 , version 1
Dominique Martinez, Gilles Millerioux. Support Vector Committee machines. European Symposium on Artificial Neural Networks - ESSANN'2000, Apr 2000, Bruges, Belgium, France. 6 p. ⟨inria-00107847⟩
84 Consultations
74 Téléchargements
