New interface
Conference papers
Fully automatic 3D/2D subtracted angiography registration
Erwan Kerrien 1 Marie-Odile Berger 1 Eric Maurincomme Laurent Launay Régis Vaillant Luc Picard
1 ISA - Models, algorithms and geometry for computer graphics and vision
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Today, 3-D angiography volumes are routinely generated from rotational angiography sequences. In previous work \cite{Kerrien98}, we have studied the precision reached by registering such volumes with classical 2-D angiography images, inferring this matching only from the sensors of the angiography machine. The error led by such a registration can be described as a 3-D rigid motion composed of a large translation and a small rotation. This paper describes the strategy we followed to correct this error. The angiography image is compared in a two-step process to the Maximum Intensity Projection (MIP) of the angiography volume. The first step provides most of the translation by maximizing the cross-correlation. The second step recovers the residual rigid-body motion, thanks to a modified optical flow technique. A fine analysis of the equations encountered in both steps allows for a speed-up of the calculations. This algorithm was validated on 17 images of a phantom, and 5 patients. The residual error was determined by manually indicating points of interest and was found to be around 1 mm.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00108049
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Thursday, October 19, 2006 - 3:40:29 PM
Last modification on : Friday, February 4, 2022 - 3:20:13 AM
Identifiers
  • HAL Id : inria-00108049, version 1
Collections
Citation
Erwan Kerrien, Marie-Odile Berger, Eric Maurincomme, Laurent Launay, Régis Vaillant, et al.. Fully automatic 3D/2D subtracted angiography registration. International Conference for Medical Image Computing & Computer Assisted Intervention - MICCAI'99, 1999, Cambridge, England, pp.664--671. ⟨inria-00108049⟩
Share
Metrics
Record views
89
