An Online Support Vector Machine for Abnormal Events Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2006
Manuel Davy
  • Fonction : Auteur
Frederic Desobry
  • Fonction : Auteur
Arthur Gretton
  • Fonction : Auteur
Christian Doncarli
  • Fonction : Auteur
The ability to detect online abnormal events in signals is essential in many real- world Signal Processing applications. Previous algorithms require an explicit signal statistical model, and interpret abnormal events as statistical model abrupt changes. Corresponding implementation relies on maximum likelihood or on Bayes estima- tion theory with generally excellent performance. However, there are numerous cases where a robust and tractable model cannot be obtained, and model-free approaches need to be considered. In this paper, we investigate a machine learning, descriptor- based approach that does not require an explicit descriptors statistical model, based on Support Vector novelty detection. A sequential optimization algorithm is intro- duced. Theoretical considerations as well as simulations on real signals demonstrate its practical efficiency.
inria-00120256 , version 1 (28-05-2007)
Manuel Davy, Frederic Desobry, Arthur Gretton, Christian Doncarli. An Online Support Vector Machine for Abnormal Events Detection. Signal Processing, 2006, 86 (8), pp.2009-2025. ⟨10.1016/j.sigpro.2005.09.027⟩. ⟨inria-00120256⟩
159 Consultations
0 Téléchargements
