Reduction of Algebraic Parametric Systems by Rectification of their Affine Expanded Lie Symmetries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Lie group theory states that knowledge of a~$m$-parameters solvable group of symmetries of a system of ordinary differential equations allows to reduce by~$m$ the number of equations. We apply this principle by finding some \emph{affine derivations} that induces \emph{expanded} Lie point symmetries of considered system. By rewriting original problem in an invariant coordinates set for these symmetries, we \emph{reduce} the number of involved parameters. We present an algorithm based on this standpoint whose arithmetic complexity is \emph{quasi-polynomial} in input's size.
Sedoglavic2006.pdf (207.53 Ko) Télécharger le fichier
inria-00120991 , version 1 (19-12-2006)
Alexandre Sedoglavic. Reduction of Algebraic Parametric Systems by Rectification of their Affine Expanded Lie Symmetries. Algebraic Biology 2007, Jul 2007, RISC, Castle of Hagenberg, Austria, Austria. pp.277-291, ⟨10.1007/978-3-540-73433-8_20⟩. ⟨inria-00120991⟩
301 Consultations
287 Téléchargements
