HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Two-level tuning of fuzzy PID controllers.
Abstract : Fuzzy PID tuning requires two stages of tuning; low level tuning followed by high level tuning. At the higher level, a nonlinear tuning is performed to determine the nonlinear characteristics of the fuzzy output. At the lower level, a linear tuning is performed to determine the linear characteristics of the fuzzy output for achieving overall performance of fuzzy control. First, different fuzzy systems are defined and then simplified for two-point control. Non-linearity tuning diagrams are constructed for fuzzy systems in order to perform high level tuning. The linear tuning parameters are deduced from the conventional PID tuning knowledge. Using the tuning diagrams, high level tuning heuristics are developed. Finally, different applications are demonstrated to show the validity of the proposed tuning method
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00122633
Contributor : Chine Publications Liama Connect in order to contact the contributor
Submitted on : Thursday, January 4, 2007 - 10:36:09 AM
Last modification on : Friday, April 8, 2022 - 3:38:02 PM
Identifiers
Collections
Citation
Georges K. I. Mann, Hu Bao-Gang, Raymond G. Gosine. Two-level tuning of fuzzy PID controllers.. IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics, Institute of Electrical and Electronics Engineers, 2001, IEEE Transactions on Systems, Man, and Cybernetics, Part B, 31 (2), pp.263-269. ⟨10.1109/3477.915351⟩. ⟨inria-00122633⟩
Share
Metrics
Record views
83
