Altered Functional Connectivity in Early Alzheimers Disease: a Resting-state fMRI Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Human Brain Mapping Année : 2006
Kun Wang
  • Fonction : Auteur
Meng Liang
  • Fonction : Auteur
Lixia Tian
  • Fonction : Auteur
Tianzi Jiang
  • Fonction : Auteur
Previous studies have led to the proposal that patients with Alzheimer's disease (AD) may have disturbed functional connectivity between different brain regions. Furthermore, recent resting-state functional magnetic resonance imaging (fMRI) studies have also shown that low-frequency (<0.08 Hz) fluctuations (LFF) of the blood oxygenation level-dependent signals were abnormal in several brain areas of AD patients. However, few studies have investigated disturbed LFF connectivity in AD patients. By using resting-state fMRI, this study sought to investigate the abnormal functional connectivities throughout the entire brain of early AD patients, and analyze the global distribution of these abnormalities. For this purpose, the authors divided the whole brain into 116 regions and identified abnormal connectivities by comparing the correlation coefficients of each pair. Compared with healthy controls, AD patients had decreased positive correlations between the prefrontal and parietal lobes, but increased positive correlations within the prefrontal lobe, parietal lobe, and occipital lobe. The AD patients also had decreased negative correlations (closer to zero) between two intrinsically anti-correlated networks that had previously been found in the resting brain. By using resting-state fMRI, our results supported previous studies that have reported an anterior-posterior disconnection phenomenon and increased within-lobe functional connectivity in AD patients. In addition, the results also suggest that AD may disturb the correlation/anti-correlation effect in the two intrinsically anti-correlated networks. Hum Brain Mapp 2006
inria-00123433 , version 1 (09-01-2007)
Kun Wang, Meng Liang, Liang Wang, Lixia Tian, Xinqing Zhang, et al.. Altered Functional Connectivity in Early Alzheimers Disease: a Resting-state fMRI Study. Human Brain Mapping, 2006, Human Brain Mapping, 28 (10), pp.967-978. ⟨10.1002/hbm.20324⟩. ⟨inria-00123433⟩
150 Consultations
0 Téléchargements
