A quasi-Monte Carlo method for computing areas of point-sampled surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2006
A novel and efficient quasi-Monte Carlo method for computing the area of a point-sampled surface with associated surface normal for each point is presented. Our method operates directly on the point cloud without any surface reconstruction procedure. Using the Cauchy–Crofton formula, the area of the point-sampled surface is calculated by counting the number of intersection points between the point cloud and a set of uniformly distributed lines generated with low-discrepancy sequences. Based on a clustering technique, we also propose an effective algorithm for computing the intersection points of a line with the point-sampled surface. By testing on a number of point-based models, experiments suggest that our method is more robust and more efficient than those conventional approaches based on surface reconstruction.
inria-00124273 , version 1 (12-01-2007)
Yu-Shen Liu, Jun-Hai Yong, Hui Zhang, Dong-Ming Yan, Jia-Guang Sun. A quasi-Monte Carlo method for computing areas of point-sampled surfaces. Computer-Aided Design, 2006, Computer-Aided Design, 38 (1), pp.55-68. ⟨10.1016/j.cad.2005.07.002⟩. ⟨inria-00124273⟩
76 Consultations
0 Téléchargements
