New interface
Conference papers
A Component Model Engineered with Components and Aspects
Abstract : This paper presents AOKell, a framework for engineering component-based systems. This framework implements the Fractal model, a hierarchical and dynamic component model. The novelty of this paper lies in the presentation of AOKell, an implementation of the Fractal model with aspects. Two dimensions can be isolated with Fractal: the functional dimension, which is concerned with the definition of application components, and the control dimension, which is concerned with the technical services (e.g. lifecycle, binding, persistence, etc.) that manage components. The originality of AOKell is, first, to provide an aspect-oriented approach to integrate these two dimensions, and second, to apply a component-based approach for engineering the control dimension. Hence, AOKell is a reflective component framework where application components are managed by other, so-called, control components and where aspects glue together application components and control components.
Document type :
Conference papers
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/inria-00126350
Contributor : Lionel Seinturier Connect in order to contact the contributor
Submitted on : Wednesday, January 24, 2007 - 6:05:17 PM
Last modification on : Friday, February 4, 2022 - 3:16:23 AM
Long-term archiving on: : Tuesday, April 6, 2010 - 8:11:59 PM
File
40630139.pdf
Identifiers
  • HAL Id : inria-00126350, version 1
Collections
Citation
Lionel Seinturier, Nicolas Pessemier, Laurence Duchien, Thierry Coupaye. A Component Model Engineered with Components and Aspects. 9th ACM SIGSOFT International Symposium on Component-Based Software Engineering (CBSE'06), 2006, Vasteras, Sweden. pp.139-153. ⟨inria-00126350⟩
Share
Metrics
Record views
133
Files downloads
601
