Super twisting algorithm based step-by-step sliding mode observers for nonlinear systems with unknown inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Systems Science Année : 2007
This paper highlights the interest of step-by-step higher order sliding mode observers for MIMO nonlinear systems with unknown inputs. A structural matching condition, stating on the possibility to design such observers and to reconstruct the unknown inputs, is derived. A finite time sliding mode observer, based on the hierarchical use of the super twisting algorithm, is developed. Then, it is shown that this observer is of interest in the field of hybrid systems and systems with observability singularities. Lastly, it is shown through an example how to relax the usual matching condition by the means of this type of finite time sliding mode observer.
TBIJSS_HAL.pdf (315.29 Ko) Télécharger le fichier
inria-00128137 , version 1 (30-01-2007)
inria-00128137 , version 2 (16-02-2007)
Thierry Floquet, Jean-Pierre Barbot. Super twisting algorithm based step-by-step sliding mode observers for nonlinear systems with unknown inputs. International Journal of Systems Science, 2007, 38 (10), pp.803-815. ⟨10.1080/00207720701409330⟩. ⟨inria-00128137v2⟩
407 Consultations
9634 Téléchargements
