Expert Programming Knowledge: a Schema-Based Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1990
Françoise Détienne
The topic of this chapter is the role of expert programming knowledge in the understanding activity. In the "schema-based approach", the role of semantic structures is emphasized whereas, in the "control-flow approach", the role of syntactic structures is emphasized. Data which support schema-based models of understanding are presented. Data which are more consistent with the "control-flow approach" allow to discuss the limits of the former kind of models.
PsyProg90.pdf (220.58 Ko) Télécharger le fichier
inria-00128352 , version 1 (31-01-2007)
Françoise Détienne. Expert Programming Knowledge: a Schema-Based Approach. J-M Hoc, T.R.G. Green, R. Samurcay, D. Gilmore. Psychology of Programming, Academic Press, pp.205-222, 1990, People and Computer series, 0-12-350772-3. ⟨inria-00128352⟩
Collections
INRIA CNAM INRIA2
79 Consultations
287 Téléchargements
