Bytecode rewriting in Tom
In this paper, we present a term rewriting based library for manipulating Java bytecode. We define a mapping from bytecode programs to algebraic terms, and we use Tom, an extension of Java that adds pattern-matching facilities, to describe transformations. An originality of Tom is that it provides a powerful strategy language to express traversals over trees and to control how transformation rules are applied. To be even more expressive, we use CTL formulae as conditions and we show how their satisfiability can be ensured using the strategy formalism. Through small examples, we show how bytecode analysis and transformations can be defined in an elegant way. In particular, we outline the implementation of a ClassLoader parameterized by a security policy that restricts file access.
Informatique et langage [cs.CL]
