Abstract : Explicit parallelism relies on transmissions of messages between processes. However, as workstations are not intended to manage this kind of communications, it is necessary to use communication libraries, known as Message Passing. Currently, only MPI (Message Passing Interface) is still used, and its use became more complexe. In order to solve this problem, a new language called MeDLey was developed, its purpose is to allow to the users an easier parallelism programming based on communications using Message Passing. In this paper, we will first overview the basics of the MeDLey syntax and semantics, before talking about the extension part of this language for the grid-decomposition methods.
