Interaction Grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Interaction Grammars (IG) are a new linguistic formalism which is based on descriptions of under-specified trees in the framework of intuitionistic linear logic (ILL). Syntactic composition, which is expressed by deduction in linear logic, is controlled by a system of polarized features. In this way, parsing amounts to generating models of tree descriptions and it is implemented as a constraint satisfaction problem.
Fichier non déposé
inria-00147385 , version 1 (16-05-2007)
  • HAL Id : inria-00147385 , version 1
Guy Perrier. Interaction Grammars. Proceedings of 18th International Conference on Computational Linguistics - CoLing 2000, International Committee on Computational Linguisitcs, 2000, Sarrebrück/Germany, France. 7 p. ⟨inria-00147385⟩
77 Consultations
0 Téléchargements
