Gasper: A Collaborative Writing Mode for Avoiding Blind Modifications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gérald Oster
Pascal Molli
Hala Skaf-Molli
In the last years network connectivity continuously expanded. However, existing collaborative environments were not designed to benefit from the fact that users are connected most of the time. For example, Wiki or version control systems allow users to work in isolation, but they tolerate blind modifications. For instance, users may concurrently perform the same task or they might work on obsolete versions of shared documents. We propose a novel writing mode for avoiding blind modifications by providing real-time information about group activities. Changes performed concurrently are filtered according to user privacy preferences and depicted in their local documents.
RR-6204.pdf (1.01 Mo) Télécharger le fichier
inria-00150013 , version 1 (29-05-2007)
inria-00150013 , version 2 (29-05-2007)
inria-00150013 , version 3 (31-05-2007)
  • HAL Id : inria-00150013 , version 3
Claudia Lavinia Ignat, Gérald Oster, Pascal Molli, Hala Skaf-Molli. Gasper: A Collaborative Writing Mode for Avoiding Blind Modifications. [Research Report] RR-6204, INRIA. 2007, pp.10. ⟨inria-00150013v3⟩
173 Consultations
213 Téléchargements
