One Click Focus with Eye-in-hand/Eye-to-hand Cooperation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
A critical assumption of many multi-view control systems is the initial visibility of the regions of interest from all the views. An initialization step is proposed for a hybrid eye-in-hand/eye-to-hand grasping system to overcome this requirement. In this paper, the object of interest is assumed to be within the eye-to-hand field of view, whereas it may not be within the eye-in-hand one. The object model is unknown and no database is used. The object lies in a complex scene with a cluttered background. A method to automatically focus the object of interest is presented, tested and validated on a multi view robotic system.
paper_icra07-v8.pdf (446.61 Ko) Télécharger le fichier
inria-00160956 , version 1 (09-07-2007)
  • HAL Id : inria-00160956 , version 1
Claire Dune, Eric Marchand, Cédric Leroux. One Click Focus with Eye-in-hand/Eye-to-hand Cooperation. IEEE Int. Conf. on Robotics and Automation, Apr 2007, Roma, Italia, Italy. pp.2471-2476. ⟨inria-00160956⟩
379 Consultations
167 Téléchargements
