Fault Detection in Autonomic Networks using the Concept of Promised Cooperation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Rémi Badonnel
  • Fonction : Auteur
  • PersonId : 830460
Mark Burgess
  • Fonction : Auteur
Fault detection is a crucial issue in autonomic networks for identifying unreliable nodes and reducing their impact on the network availability and performance. We propose in this paper to improve this situation based on the concept of promised cooperation. We exploit the promise theory framework to model voluntary cooperation among network nodes and make them capable of expressing the trust in their measurements during the detection process. We integrate this scheme into several distributed detection methods in the context of ad-hoc networks implementing the OLSR routing protocol. We quantify how the fault detection performances can be increased using this approach based on an extensive set of experimentations performed under the ns-2 network simulator.
Fichier non déposé
inria-00167717 , version 1 (22-08-2007)
  • HAL Id : inria-00167717 , version 1
Rémi Badonnel, Mark Burgess. Fault Detection in Autonomic Networks using the Concept of Promised Cooperation. 18th IFIP/IEEE International Workshop on Distributed Systems: Operations and Management (DSOM'07, MANWEEK'07), IEEE Communications Society, Oct 2007, San José, CA, United States. ⟨inria-00167717⟩
69 Consultations
0 Téléchargements
